Old 07-30-2017, 04:56 PM   #1
Brian in Tucson
Originally Posted by Boxtaboy View Post
To pull out the CD holder, just push the button of one or two cd slots so that they pop out (as if you're removing a cd from the holder). Then, just grab a hold of those open cd slots, and pull with both hands. The whole cd holder will just pop out. Then, you can pull out the open slot below it by just yanking it out.
To remove the rest of the console (if that's what you're trying to do), just use your hands to pull out the leather panels from the side. They just pull out as they're held in by clips. Then, after pulling out all the leather panels, you will see screws/bolts that you can undo to get the entire frame of the console out. The batwing piece under the open slot just pops out as well.
I'm just learning this car 10 years old. It's like the center dash and upper console was designed by idiots. Stupid filler stuff where USB & guages could go. A double din modern radio. Glad none of this stuff worked on my Boxster, and I can replace it with cleaner modern stuff.
2001 Boxster
2007 Toyota Highlander
