Old 07-20-2017, 12:17 PM   #3
Nmbrsix
Originally Posted by Racer Boy View Post
It's strange that the symptom you are getting only occurs over 75 mph. If the problem is a normal mechanical one, it seems like it would show up at all speeds. Is your front bumper cover undamaged? Are all the under-body covers in the front intact? I'm wondering if maybe something with your bodywork is amiss, and causing some lift at higher speeds.
New front belly pan installed this spring; bumper cover undamaged.
The car had this issue with both prior sets of front tires, too, so I can't place the blame on the Contis (although they do tramline more than the others did).
Funny enough--I opened the frunk a couple of days ago to discover that I still had the box containing the OEM suspension for my Mk7 GTI in there. So there is some weight over the front wheels--with no change.
The steering is nice and heavy at lower speeds, only getting light around center at higher speeds.
'02 Boxster S
'16 GTI PP
'17 Bolt (with a B)
Nmbrsix is offline   Reply With Quote
