Old 07-17-2017, 08:27 PM   #21
Racer Boy
Racer Boy
Racer Boy's Avatar
Originally Posted by Need_for_speed View Post
Anyway, we did a test drive and the woo-hoo is still there. It's extremely intermittent, totally independent of throttle position. It almost seems like it has something to do with the way air flows over the car. Now I'm starting to wonder if it's a hood adjustment thing, or if I have a weatherstripping issue somewhere. I've replaced just about every damn component on the evap system, so now I'm grasping at straws...
You can try taping all the seams of the bodywork on the front of the car with duct tape. See if the noise goes away, and if it does, remove one piece of tape at a time until the noise comes back. Viola! You've found the culprit (hopefully).
The nice thing is that it is cheap to try that, tape is cheap. If it doesn't work, then you aren't out too much.
