Old 07-17-2017, 11:13 AM   #17
Need_for_speed
Originally Posted by mipstien View Post
I had this problem with the magnetic switch. I thought it was directly related to the wooo noise because they happened at the same time. I bought a new neck and everything and then when looking to replace it saw the little seat it went in and saw the wire hanging down.
That little switch caused me all kinds of problems. It made my car hard to fill up, hard to start, and flooded it once. It even made the AOS throw a code when it flooded.
If I had known, I might have ordered a new reed switch and installed it along with the filler valve to head off any future issues. At the moment, I can't seem to find a part number for the little bugger. Did you replace yours?
UPDATE: I may have found the part number: 996 613 224 01 (looks like around $20 from Pelican). Not sure how to install -- assume it's a splice.
Need_for_speed is offline   Reply With Quote
