Old 07-15-2017, 12:28 PM   #1
911monty
911monty's Avatar
Originally Posted by Walshie View Post
Hi 911monty. Thanks for your reply. I have changed the bank 1 sensor, total bugger to get out, cleared the faults but now I have misfires on bank 2 cylinders 4,5 and 6. Is this likely as I have changed bank 1 sensor with a bosch and it is not matched to the original and has thrown that one out. Not really sure how these things work.
Hey Walshie: Did you disconnect the battery to reset the ECU? The learned values from bank 2 will still be stored and need to be reset. Disconnecting the battery will reset to base map.
