Old 07-15-2017, 11:53 AM   #1
Walshie
Man I expect someone to jump from headlight washers not working to the IMS. LOL.... The precat 02 sensor output adjusts the injectors fuel pulse attempting a stoichiometric AFR. If reading incorrectly this can cause a lean/rich condition. A lean mixture can cause misfires as well as holes in piston from detonation if severe enough. I'd say the pre cat 02 sensor bank 1 is a likely culprit.
Hi 911monty. Thanks for your reply. I have changed the bank 1 sensor, total bugger to get out, cleared the faults but now I have misfires on bank 2 cylinders 4,5 and 6. Is this likely as I have changed bank 1 sensor with a bosch and it is not matched to the original and has thrown that one out. Not really sure how these things work.
Walshie is offline   Reply With Quote
