Old 08-09-2006, 06:51 AM   #2
no_substitute
Mystery Piece of plastic
Originally Posted by RandallNeighbour
Another way to determine if the window regulator is worn out is to have a friend sit in your car and raise and lower the window with you standing outside looking at the distance between the rubber gasket and the glass at the front of the window and the back of the window when being raised. If the front or rear of the glass (front being closest to your front bumper and rear being closest to your rear bumper) is rising lopsided or crooked, your regulator has worn to the point of not working well.
The window raises up and down with the window button normally. There appears to be no lopsided effect. When I push the window down to it normal drop postion and close the door, it raises to the correct position. The only part of the window not functioning correctly is the drop.
I have heard about some little white plastic piece inside the door that has a tendency to fail by developing a fracture. Have you heard about this mystery piece?
no_substitute is offline   Reply With Quote
