Old 07-07-2017, 08:40 PM   #14
Boxstard
Originally Posted by Need_for_speed View Post
I just ordered the valve for the fuel filler neck. It's the least expensive of the remaining options, and in my opinion, probably the most likely remaining culprit. I should have it in place by the end of the month. I'll keep you posted.
I am also having this type of noise issue, but only at idle on warmer days above 75F or so with half tank of less fuel, under isolated situation and never noticed it while driving. I changed the filler neck valve which reduced the noise level and duration but still there...
Hope this thread lead to a solution.
