Old 06-30-2017, 10:02 PM   #10
mmassey0125
The clock spring is part of the airbag. The turn signal needs replaced. It is not an easy job. Window is the assembly with the micro switch. Again not an easy job. Both can be done if you work on your car and are mechanically inclined. You will need to purchase a few tools to accomplish both so you may want to take it to your mechanic for an estimate and then price out the parts, tools and time to do yourself. I replaced my inside door handle assembly. What would take my mechanic about an hour took me 4 hours so take that into consideration. Good luck!
Sent from my SAMSUNG-SM-N920A using Tapatalk
mmassey0125 is offline   Reply With Quote
