Old 06-26-2017, 02:11 PM   #1
Racer Boy
Racer Boy
Racer Boy's Avatar
The first thing I would check would be the bleed valves on the calipers, make sure that they are tight. Most likely you'll have to fix(rebuild/replace) the master cylinder. Your symptoms are what normally happens when the master cylinder goes bad.
