Old 06-17-2017, 06:17 AM   #15
itsnotanova
Originally Posted by Javi Cooper View Post
The sponges under the carpets are beginning to piss me off. Just when I think my drains are clean and my interior is finally dry, a heavy rain will soak everything up and I have to start from the beginning. Can we just get rid of that spongy insulation? Will it detach from the carpet? What is it good for anyway? Sound deadening? Heat insulation? Has anyone removed it and noted any difference?
EDIT: Then again, maybe the giant sponge does serve a purpose by protecting the immobilizer from getting wet...
Yes you can remove the insulation but it's a very messy situation. I had to use a wire wheel on my grinder to get it off. The noise level can be very loud or not noticeable at all. It all depending on what road surface you're driving on. As for the heat insulation, the HVAC system is so great on these cars I never find it getting too hot or cold.
Woody
