Old 06-12-2017, 11:19 AM   #11
Need_for_speed
I'm bumping this to see if any of you kind folks can give me any direction as to what to try next.
2000 base 2.7L with 69000 miles.
Issue: "Blowing bottle" noise from fuel fill area. Occurs with light acceleration. No CEL or codes.
I've done the following:
Replaced regeneration valve on intake manifold.
Replaced the two valves inside the passenger fender area (behind headlight).
Replaced gas cap.
I'm considering the following:
Replace the valve on the carbon canister 996-605-201-01
Replace the valve on the fuel filler neck 996-201-143-01
Replace the vent tube 996-201-259-05
Replace carbon canister (do they go bad?)
Replace the valve housing in the front right fender (996-201-231-01)
What else could fail and cause the noise? Am I overlooking something? I cannot abide the noise...
Need_for_speed is offline   Reply With Quote
