Old 06-04-2017, 08:37 PM   #18
dulmer
dulmer's Avatar
Originally Posted by 356Guy View Post
My amp isn't getting power among a few other issues. I went through the pin outs and diagrams. I'm pretty sure that I have the wrong harness. The simple harness can't possibly work with my sound system. If I look at the current wiring and the Continental and Becker diagrams I see the problem:
  • My current wiring does not use the B block (apparently this is unused in HiFi option/Nokia cars)
  • My current wiring uses the C block pins to send the signals to the amp; the Continental diagram doesn't show that the C block pins are used for anything other than the C4 and C6 pins for SWRC.
  • The only output to the amp on the Continental is the B block which explains why I have no sound because it is not being used
  • I therefore need a harness that goes from the Continental B block to the existing harness C1 block. Do I also need a line-out converter (LOC)?
  • Also, there is no ground pin in the Continental head B block. Does my amp need that?
  • Reference https://rennlist.com/forums/993-forum/896189-installing-the-continental-tr7412ub-or-radio-6.html
If the above is correct then the other/M490 harness should work. This is what it is supposed to do:
Swap of Terminal 86s and 30 pins (switched and permanent 12V)
Wire for connection to Nokia/Bose amplifier power on circuit
Line Output Converter (LOC) for connection to existing amplifier
Looking at the picture it looks it is exactly what I need. It also means that not having option code M490 does not necessarily mean that the simple harness will work.
What stereo option do you have? Which amp does your car have?
dulmer is offline   Reply With Quote
