Old 06-04-2017, 10:16 AM   #1
The Radium King
The Radium King's Avatar
the problem w having a temp sensor to turn on your pump is no place to put it? most use the fill and drain openings on the transmission to circulate the oil, so no place for the sensor. you put the sensor on the cooling system and it doesn't see flow unless the pump is running - sort of a chicken and egg situation. unless the PO drilled the transmission for a sensor or the oil return?
