Originally Posted by 356Guy
I installed the Continental head unit. It took maybe 15 minutes because I had to trim the sides of the openings slightly. I plugged in the factory connections using the supplied adapter harness. Everything seems to work including Bluetooth but no volume/output to amp and speakers I guess. Email sent to Bergville. Any ideas? Connections checked, fuses checked, its not on mute
Which harness did you order?
