Old 06-01-2017, 06:26 PM   #13
rick3000
There Is No Substitute.
rick3000's Avatar
I spent a few hours researching the transmission oil for the '99 before I changed mine. Porsche really went all out on the early five-speed's and the oil is in fact specific to the transmission. It's a shame most dealers will try to sell people the wrong fluid, because they don't stock the 20L drum. Don't trust the parts guy at the dealer!
Originally Posted by Vidyashankara View Post
Awesome, thanks! Can you explain the potential alignment issues?
The hole will give access only to the drain plug right? I am not sure if i can access the fill plug without remove the tray.
The plate is part of the suspension system, it acts as a brace between the rear suspension, and when you remove it, you can change the alignment of the car. If you choose to remove it and not drill a hole, use jack stands and not ramps. By taking the weight off the wheels you will reduce the chance of messing up the alignment. When I removed the plate I used stands, and when I had my alignment checked afterward it had not been affected.
