Old 05-31-2017, 02:27 PM   #10
paulofto
2003 S, Arctic Silver, M6
paulofto's Avatar
Originally Posted by Vidyashankara View Post
I will try and do this in the next couple of days. I still need to remove the aluminum tray and diagonal brackets covering the transmission right?
Save time, effort and a lot of potential alignment issues and drill an 2" diameter access hole in the tray. You'll be happy you did.
To remove just a little fluid, remove the fill plug and jack up the from end, some fluid will leak out the fill hole and then level the car and see if the 11 mm difference is met.
