Old 05-29-2017, 08:09 PM   #3
Gelbster
There is also a seal under the vent valve(the one with the s/s wire bail on it) .That could leak?
If you are just getting steam around the cap, and on the trunk lid above the cap, replace the cap, it is a common point of failure. I would also ensure that the coolant tank is not overfilled. If it is not just steam, look for white residue around the coolant tank, the OEM fluid leaves it behind to help identify leaks. Also try reaching under the carpet near the tank to see if it is wet.
