Old 05-29-2017, 11:00 AM   #17
Vidyashankara
>>>Replace the bottom plug on the transmission, but don't tighten it too tightly (18 ft-lbs or 25 Nm maximum). These plugs do not have a tendency to leak (transmission oil is thicker than engine oil). If it does leak later on, you can always tighten it a little more. Now, add transmission oil to the case. The best method of doing this is with a hand operated oil pump. These are available from most auto parts stores and attach to the top of the plastic transmission oil bottle. They work very similar to the liquid soap dispensers you find in most bathrooms. Pump the transmission case full of fluid until it just starts to run out the filler hole. Replace the filler plug and clean up the few drips that might have run out of the hole. Tighten down the filler plug in a similar manner to the drain plug.
ISnt that to check the fluid level? The procedure asks to fill the oil until it overflows?
Vidyashankara is offline   Reply With Quote
