Old 08-02-2006, 11:34 AM   #6
Pablito
You can also use a set of ramps that lifts the car about 6 inches from the ground so you can slide under it....I also do this job my self as well as the oil. The oil filter is as easy as the plugs...just remember to change the gasket from the filter cover when you change your filter element.
1998 Boxster - trying to survive!
"I am who I am, your approval isn't required" - Jack Nicholson
Pablito is offline   Reply With Quote
