Originally Posted by particlewave
What happens when you press the lock switch on the dash with both doors closed?
Lock switch's red light goes on, driver door locks, passenger door
does not. After that, pressing the button again either way will not change anything (red light stays on, driver door stays locked until door is opened from inside).
What happens when you lock using the key in the door?
Same symptoms as using the remote: Door locks and gas lid engage for a split second, then go back to where they were (unlocked doors, locked gas lid)
What happens when you turn the key to the lock position 3 times in a row?
Driver door
stays locked and gas lid does the noise only once - basically the first half of the current symptoms. However, passenger door still
does not lock.
#1 and #3 make me think that there is a problem with the door lock on the passenger side. It won't engage for some reason so the immobilizer thinks the door is open or unlocked and the alarm won't engage. At first I thought it could be the door switch doing that but the window and dome light seem to know fine when the door is opened or closed. I think at least it has been narrowed down somewhat. What do you think?
