Old 05-21-2017, 08:59 AM   #10
jsceash
jsceash's Avatar
Also I did not have to bend or shorten the water bypass nipple on the top. The hose was not shortened. Although I can not get a picture of it there was still enough room to put on the hose while the oil cooler was mounted, and now there is about 1/2" clearance. With the mods that you can see the top is tight. The oil cooler went in sideway angle down at about 45 degrees, front end first. Then leveled out, and I turned it 90 degrees to bolt it down. No other parts were removed.
