Old 05-18-2017, 05:27 AM   #1
tlc356
plastic rear window
If you want to lower the top without geting out of the car be sure to do so when it is warm outside. Also, you will get a lot of wear and scratches on the plastic so get and use Plexus (found in boat and motorycle shops but today on line).
I was willing to get out of my car and always cleaned off the rear window before lowering so it was still clear after 15 years when I replaced it. It cracked at a spot that developed when i first got the car and lowered the top when it was about 40 degrees F.
Good luck
tlc356 is offline   Reply With Quote
