Oil on passeger side crankcase
Well I smelled oil today after getting home from work so I decided to check it out. Upon inspection I found oil pooled on the top of the passenger side of the crankcase. I did notice that the vacuum hose that goes to the cut-off valve is broken off. Will this cause the oil leak on the top of the motor? While I'm at it what is that hard plastic hose called and can it be replaced with any other hose? Any ides would be appreciated.
