With some hints from JFP , I used my old oil cap and a Home Depot fitting.Just drill+tap and a little sealer. 1/4" NPT x 1/8" barb IIRC
The Manometers are available for around $30 from Amazon.
I used sufficient tubing to reach from the trunk to inside the cab so I could blip the accelerator and see if anything alarming happened.
I had just fitted a new AOS so was interested to test it since some are defective new !So the Manometer Test becomes a routine part of AOS replacement now.
