Old 05-03-2017, 12:31 PM   #2
djw8282
djw8282's Avatar
Wheels can be repaired. Its not a DIY, you want to go to a place that specializes in wheel repair.
They can fix cracks and bends.
That being said, I probably would not want to uses repaired wheels on the track. Far too many other hings can go wrong and why take more chances than you needs to. For DD, a different story. Far less stress than on the track. I noticed a small crack on the outside edge and it did not go completely through. I had it repaired and no issues or problems. They are my DD wheels
It must have happened hitting a pot hole (thank you CalTrans!). The wheel repair shop also notices it was slightly bent and fixed that as well.
Keep an eye out online on forums and gasp, craigslist. I bought both sets of my track/AX wheels that way. I paid $350 for one set including new HTR ZIII tires and $200 for the other set. No need to spend $1000's on used wheels.
Also check your local PCA chapter's classifieds. Some great deals there too
Thanks Jay. I'm still searching!
djw8282 is offline   Reply With Quote
