Old 05-02-2017, 06:19 PM   #11
Cbonilla
Originally Posted by Boxtaboy View Post
I may be wrong, but you might want to consider removing the other tab as well. If you leave one tab there, when the top is folded, the other side may be tilted, and cause something in the frame to not sit right. I'd keep both sides on an even plane. JMHO. You can always return both tabs if you want in the future. Oh, and after removing the tabs, I also removed the tape. There's no reason to have any additional stiffness in the fabric while it's moving up and down, and no longer anything pressing on it.
Removing the second tab is under considerable. As for the tape, I think I will leave it on. As I mentioned, I already have a hole in one side and the other side is showing significant wear
Cbonilla is offline   Reply With Quote
