Old 05-02-2017, 05:07 PM   #11
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by Cbonilla View Post
Applied the tape to both sides. On the driver side it had worn completly through and the passenger side was very worn, almost translucent. I took the tab off the driver side and will monitor operations before doing the other tab.
Glad it wasn't just me.
I may be wrong, but you might want to consider removing the other tab as well. If you leave one tab there, when the top is folded, the other side may be tilted, and cause something in the frame to not sit right. I'd keep both sides on an even plane. JMHO. You can always return both tabs if you want in the future. Oh, and after removing the tabs, I also removed the tape. There's no reason to have any additional stiffness in the fabric while it's moving up and down, and no longer anything pressing on it.
