Thread: Durametric Help
Old 05-02-2017, 08:05 AM   #1
Gelbster
Jeepers,
JFP is correct.He has had a lot of chance to practice :-)
If you just want to clear a code a $14.99 Harbor Freight Code Reader works great.
If you want to try to figure out what caused that code ,use the Durametric.
Unless it is an aberrant code, clearing a code is useless for passing Smog or peace of mind.
Digging deeper into the Durametric usually gives you great clues about where the problem is.
From a Smog Test perspective clearing the Code (CEL) does nothing for an associated Ready Status failure. So your car will fail the Test anyway.
Make sure you have the latest download of the Durametric software.They had several updates of updates recently and you'll need those to make the Activations work correctly.
