Old 04-29-2017, 08:54 AM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by Fintro11 View Post
Mine started out like that, then there top would shutter when closing. I ended up with a hole on each side. I checked the transmissions and motor and they are both fine it is something wrong with the frame not wanting to fold properly. I disconnected the arms so I can manually lower the top but the clamshell is still powered. When looking at the top from the inside I noticed a bar with a tab sticking up. That is what rubs on the spot.
Thanks for the info. Is there a way to adjust the bar so that it doesn't touch the fabric you think?
