Old 04-29-2017, 08:39 AM   #1
ttmedical
Originally Posted by Boxtaboy View Post
I'm noticing that after you've had the top down for a while, and then you put the top back up, there's a raised bump in the fabric that eventually flattens, but is clearly a point where eventually I think it will wear through. Seems as if a metal bar is poking it out when the top is down or something. Anyone with an 03/04 top not have this come up? I'm wondering if there's an adjustment I can play with to prevent it. It happens on both sides.
YES! Thank you for posting this picture; I have an 03 base and now I know I'm not alone! Mine has it on both sides and has even gotten far enough to put a small 5-8mm hole in it. I first tried suturing it closed with nylons and that held for a year or two and now I just put some extra thick gorilla tape on the inside. I put the top up and down at least once a day if weather is good and always store the car top up in my garage. I have no clue what causes this though but at least there's someone who has the exact same thing.
ttmedical is offline   Reply With Quote
