Thread: Offsets ... ?
Old 04-20-2017, 03:20 PM   #1
JayG
On the slippery slope
JayG's Avatar
I run 20 mm front and 15 mm rear spacers with factory wheels and offsets on my 04 S
be sure to get longer lug bolts or studs if you will be using spacers
for studs, you need 90 mm with a 20 mm spacer. Might be able to get away with a 75 mm with a 15mm spacer, depends on the stud. Most of the longer ones have an unthreaded space of around 15 mm at the end. For safety, an open end lug nut should have at least 15 mm of thread showing past the not
2004 996 Targa Tip
Instructor - San Diego region
