Old 07-27-2006, 10:57 AM   #1
deliriousga
deliriousga's Avatar
It's probably the flywheel balance or a deteriorating pilot bearing. We have the same problem between 2700-3200rpm. It's a little worse in the lower gears than the higher ones. Watch the rpm and see if it's the same no matter what speed you are going, then you'll know if it's a driveshaft issue (flywheel, pilot bearing, clutch) or an axle/wheel issue.
1966 Wife White/Brown Top
