Old 04-15-2017, 08:07 AM   #2
cheese
Originally Posted by eicheldp View Post
Hi Cheese, I actually did that back in March when it got warmer. I checked the pulleys and the tensioners for both play and movement when I replaced the belt.
Earlier today, I started the engine and listened closely, no whine while idling.
Turned the steering wheel lock to lock, both right and left - no whine.
Revved the engine a few times while in park and in neutral - no whine.
I did not go out for a drive due to other obligations (Honey Do List) but I will try to get out tomorrow and see what's up.
Would it be worth while to plug in the duramatic. Would it show any transmission problems?
I would definitely plug in the durametric. I suspect you have an automatic transmission. How recent is your last transmission service? Mine is a 5 speed and usually begins to wheeze a bit when fluid change is overdue. With the top down, on a quiet winding road you can hear it loading and unloading the gears as it corners or climbs small elevation changes. Fresh fluid has put the muzzle on my Getrag greyhound.
cheese is offline   Reply With Quote
