Old 04-13-2017, 07:53 AM   #1
911monty
911monty's Avatar
Originally Posted by Syracuse986 View Post
Thank you for the directions! I am going to tackle this now. When you say retrieve the hose from the bottom of the car, will I need to unscrew the plastics protector on the bottom of the car?
You may have to remove the under body lining, It will depend on where it falls to. Once on jack stands you should be able to look up from underneath and see the hose if it is still in it's hole into the wheel well. If you have someone helping you it will be much easier.
