No fun but can be done. If you haven't driven then it's likely still hanging by it's hose. Jack up and place on jack stands. Remove driver side tire. Look on side of wheel well about 1/4 down behind the strut. You will see a round ~1/2" hole where the drain's hose comes out. Push the hose out and retrieve from under the car. The drain grommet is a 90 degree bend with the hose attached. Please get the part number from the grommet and post it here for future reference. Now comes the really fun part. You will need to insert from the top inside the frunk. You will need to use something like a 1/4" dowel about 2 feet long. As you insert the hose and grommet down through the top insert the dowel through the wheel well into the hose end to guide it into it's drain hole. Now you can work the grommet into it's hole, This part is no fun be sure to have a large swear jar, you may fill it. Good Luck
