Old 04-11-2017, 05:28 AM   #21
pidj
pidj's Avatar
More than once, we have been asked to do a PPI on a vehicle that had a very recent IMS transplant, only to find metal in the sump and filter, which is why the owner tried to do a quick retrofit and then dump the car. Considering what a retrofit costs, I am always suspicious of someone that does one and then immediately puts the car up for sale.
So why does it matter if there is metal present POST IMS change? When we detect metal, we swap the IMS (to alleviate the metal presence) - would more frequent oil changes and monitoring not clear the shavings? If not, then any metal presence would mean the engine is toast regardless of what was or is done, non?
It also begs the question about the $$ 'solution' option (oil pumped into bearing-less 'bearing')? Nedlands is right: What are you supposed to do? Doing it could be bad, not doing it is bad, metal shavings after doing it is bad .... bad bad bad.
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
