Old 04-07-2017, 01:24 PM   #1
alex.rhodes
Rear Control Arms - Help
I'm trying to replace the rear control arms. I have been able to loosen all of the required hardware. I noticed the nut holding down the ball joint is unable to be removed from the ball joint while still attached to the wheel bearing carrier. I used a pickle fork to create some space between the carrier and the control arm. At this stage, I am unable to go any further. The ball joint will not slide out of the carrier. What am I missing?
alex.rhodes is offline   Reply With Quote
