Old 04-03-2017, 09:50 PM   #14
auBoxster
auBoxster's Avatar
The only time we have seen the newer PTFE RMS seal leak is when they were installed incorrectly, with the wrong installed depth, dirty seal area, or use of any kind of sealer being the most common issues. If the crank and seal bore were cleaned, and the seal installed dry and to the correct spec, they seem bullet proof.
Unfortunately not everyone in the world can get you to perform their RMS seal change - so they have to rely on themselves or someone else to do it right, and that's taking a chance that it won't be done correctly (as you've pointed out).
So when the RMS wasn't leaking, taking that chance for no extra gain seems a little bold and bordering on foolish.... YMMV
auBoxster is offline   Reply With Quote
