Old 03-22-2017, 08:41 AM   #13
DaveNW
DaveNW's Avatar
Originally Posted by jcslocum View Post
I would make a point of changing the bearing out if your inention is so keep the car long term. The IMS Solution is a $1725 kit and the labor can't be $2275 to do the install. I have done the change, not with this kit and the labor seems quite high. You should get an itemized estimate for the work. The 30% comment is also quite a bit higher than reported....
He's quoting the $1725 for the IMS Solution, "as much as" 18 hours labor @ $100/hour, (a discount off his normal rate), fluids, and tax. Includes the RMS as well, since he's in there. So his quote "could be" $4K, and would be less, if labor was less. He says he won't know till he gets in there, but wanted to warn me that it could be that high. He's a good mechanic I trust, (known him for years), but the price was still a bit hard to swallow.
The 30% failure rate is a comment made by someone else, not me.
Dave
DaveNW is offline   Reply With Quote
