Old 03-21-2017, 09:48 PM   #7
jakeru
What was your OEM shift knob style? They made a change around 2000 or 2001 from the two-piece leather boot/knob to the integrated one-piece knob/boot, right? Kind of an unexpected observation about it adding vagueness. Was it loose fitting over the steel shaft? Was the leather covering loose on the knob structure?
The 2001 style shifter I like quite a bit. I particularly like how ergonomic it is. The leather (as opposed to all metal - had those before) feel nice in a wide range of temperatures and have good feel. The 2001+-style knob is constructed with a hard rubber core with leather wrapping.
As for the 987 shift console, I also really like it, and also have mine with the Phenix engineering bushings as well. (DIY-style gt3 shift console.). When properly installed, they have absolutely no noticeable radial or axial slop, but I did find the installation a bit of a challenge and needed to redo it with varying thickness shims to get the axial slop completely blueprinted to perfection.
With the aftermarket style shift consoles, the axial slop can be adjusted with set screw adjustments, but the design has other pros and cons. The stock lateral motion translating mechanism of the stock shift console, for example, transmits force through several square millimeters of surface area, while the imported/aftermarket style concentrates it through a single point where the replacement metal ball makes direct contact with the the original plastic frame. I haven't tried ben's shifter, but after manufacturing custom ball-bearing shifter components myself, I honestly don't see what benefit they could add for something as slow-moving as a shift assembly over rigid, lubricated, low-clearance bushings, such as the gt3-style solid metal bushings, a la properly installed Phenix engineering bushings. Very small ball bearings are also very fragile and must be installed very gently, (only a few pounds of axial force) so they don't develop noticeably "rough" operation or become damaged. It's also tricky to install both inner and outer parts with sufficiently low clearances such that the overall slop will be less than a well-designed solid bushings. There are certainly add a lot of extra moving parts that can fail.
I personally think the 15% shift reduction provided by the 987 console is "just right" - I see no need (and have no interest) in going further on the reduction... But, to each his own. I found many other sources in the 986 five-speed shift linkage where there is significant slop aside from the shift console, (including a significant amount inside the transmission itself) so regardless of which shift console you choose, simply replacing the shift console is not going to cure all of the slop. Replacing a worn-out shift console with fresh or upgraded components can make a noticeable improvement, though. Anyone who says that merely replacing a shift console will magically cure all noticeable slop, is either incapable of properly recognizing and noticing slop, or is simply a not credible/reliable information source - in my opinion. Slop can be objectively measured, and in my experience, it comes from not just one, but multiple sources.
Glad people here are enjoying forum-originating products, though. I can certainly appreciate that! Cheers!
2001 Boxster
