Installing.
1. Run the top until the driver side motor arm bolt hole is a about 4-5 O'clock
2. set the back of the roof into the rear deck. push it back then set the front pivot down into the pockets they rest in.
3. Wiggle the frame and eye the front mounting hole to insert the front bolt. 13mm ratcheting box end wrench and run the bolts in each side about 1/2 way.
4. Lift the top with someones help if available either side arm insert the rubber buffer brass ring Tee shoulder spacer and Flat head socket screw in the arm and fasten it to the crank.
5. Repeat step 4. on the other side.
6. Either side wiggle the top frame and align the rear lower bolt hole the body nut hole and insert the bolt 1/2 way. (I find I have to push the frame down and froward)
7. Repeat on the other side.
8. insert the center bolts in the lower frame then tight the 2 lower screws on both sides
9. clip the roof cables and then the rear cover.
10. Lower the roof Tighten the front bolts and install the seat belts.
