Old 03-18-2017, 02:28 PM   #21
P_Carfahrer
Pathological Tinkerer
Originally Posted by Paul View Post
You said:
the new immobilizer and two key transponders (I will reuse the two cut keys that were with the car) I just ordered will not be here until early next week.
Did you also order a matching DME? If not you will need at least the codes for the existing DME and the new immobilizer plus at least a PST-2.
I made an appointment for Wednesday with the local dealership to program the new immobilizer and key transponders. As far as the DME, I believe codes are based on the car vin and when programming a new immobilizer the service rep has to acknowledge the vin code is correct. At that point the immobilizer is "locked" to that vin code and cannot be reprogrammed.
P_Carfahrer is offline   Reply With Quote
