Old 03-07-2017, 10:03 AM   #1
alm001
01101
Easy way to disable fueling?
I want to put a starter disable switch somewhere in the car, but then I figured it could serve a dual purpose if I can disable the injectors and turn the car over in the spring without it firing to get the oil circulated.
Would disabling the fuel pump be enough, or could I interrupt the CPS to stop the injectors from firing?
alm001 is offline   Reply With Quote
