Old 03-06-2017, 01:23 PM   #10
Sweezy804
Originally Posted by bwdz View Post
I asked but still don't see the answer, what did you get for ohm values when you tested it? Replacing a part with a new part is usually a way to eliminate something but it can also get you into a whole world of problems when you assume the new part functions as it should without testing it because you will chase other problems when the real problem can still be that part.
Hey i didnt test it i just figured if i change the cps it would do the trick
Sweezy804 is offline   Reply With Quote
