Thread: Heater problem
Old 03-03-2017, 09:11 AM   #3
jeeper31
jeeper31's Avatar
Originally Posted by jsceash View Post
The heater supply and return on 2 small hose under passenger seat so it's easy to get air trapped. Try the air lift if you have one or burp the tank valve if you don't I've even laid under the car and squeezed the hoses alternately.
Can you use the air lift with the coolant in the car or do you have to drain and refill?
jeeper31 is offline   Reply With Quote
