Old 03-02-2017, 05:48 PM   #1
mikefocke
Brake fluid level check
Recall when last oil change done (should be before hybernation).
Drive gently for the first 5 miles as lubrication needs to circulate in the transmission and drive train too. Plus you need to grind off any surface rust on the rotors with easy stops before you need to STOP RIGHT NOW.
