Thread: Heater problem
Old 03-01-2017, 04:03 PM   #1
jsceash
jsceash's Avatar
Originally Posted by jeeper31 View Post
I think the heat wasn't as good as it should be before I did the water pump.
If I had an air pocket wouldn't the heat be intermittent? Start off hot then go cool for a bit then back to hot?
The heater supply and return on 2 small hose under passenger seat so it's easy to get air trapped. Try the air lift if you have one or burp the tank valve if you don't I've even laid under the car and squeezed the hoses alternately.
