Thread: Heater problem
Old 02-28-2017, 02:53 PM   #1
paulofto
2003 S, Arctic Silver, M6
paulofto's Avatar
Originally Posted by jeeper31 View Post
Just replaced water pump and thermostat. Flushed coolant out and added new. Now the heater takes a long time to get warm and never seems to get as hot as it should.
Opinions?
Okay, so the heat was fine before you changed the pump and thermostat? Not to discount 78F350 but I would venture that the heat issue has something to do with the pump and/or thermostat. General rule of thumb; look at what you last did before the issue arose. Air in the system, coolant level, DOA faulty thermostat or pump could all be part of it. Some questions; Does the temperature get to ~180 F? Does it say there? Does it rise and/or fall when the heater is activated?
