Old 02-14-2017, 02:12 PM   #2
Ronin325i
Originally Posted by Anker View Post
You say you have a light dimming issue. If that's the case you either have a bad battery or an alternator or voltage regulator issue. Have you checked the voltage off the battery terminals when shut off and when idling/running. The first needs to be around 12.5V and the second in excess of 14V.
If power is low all kinds of weird symptoms will arise.
I have checked all of the power regulations. I get the same readings at the battery and at the ECU.
At rest = 12.5v DC
Running = 13.8v - 14.1v DC / 0.05v - 0.08v AC
Ronin325i is offline   Reply With Quote
